RESOLVED: Arlo Base Station Appearing Offline
Hello Arlo Customers,
We are aware of a reported issue for some customers where the Arlo Base Station is appearing offline. We are actively investigating this issue and working to resolve it.
If you are currently experiencing this issue please reply to this thread with the following details so we can further isolate the issue:
Base Station firmware:
Device type showing offline (Arlo, Arlo Pro, Arlo Pro 2, Arlo Baby, Arlo Q, etc.):
Internet Service Provider:
Exact error message:
The application used (iOS, Android, Web):
We apologize for the inconvenience,
Arlo Team
That is GREAT news @jayoma! Thank you so much for the immediate feedback! 🙂
Kind Regards,
ChristineT
____
Please click KUDOS or REPLY if you found this helpful.
Does not work. Still showing offline. FW 1.9.8.0_16666. IPhone App v. 2.5.0.
Did it require BS boot. I am not in a position to do that.
Please do not mark this as resolved as it clearly is not.
Good evening @T2342344,
It should not require a reboot. Give me a moment to investigate. I'll be back in touch with you shortly! Can you please send me a private message with your base station serial number so I can escalate your case?
Thank you in advance!
ChristineT
____
Base Station firmware: 2.4.13.870_20870
Device type showing offline: Arlo x 4 and Base station
Internet Service Provider: Telstra
Exact error message: Base station ofline
The application used: Android and web
Hi
I am still getting this error message I am in australia and the time is 4.51 p.m. on Tuesday 14/5/18
Any update re problem?
Pretty dysfunctional here too - first noticed about an hour and a half ago and it's been the same since. Cameras all show up initially on login (browser or app) and can use live view, but no status indicators appear, there's no ability to record and motion detection isn't working. After a minute or two logged in, the cameras then all show as offline. Base station also appears offline in device settings, but there's three solid green lights on the base station itself.
Just power cycled the base station and waited a while. No change.
EDIT: Just PM'd base station serial to ChristineT.
EDIT 2: Additional details as requested in initial post.
Base Station firmware: unknown, as doesn't show up in settings while base station offline.
Device type showing offline: Arlo (original) base station, Arlo (original) cameras, Arlo Pro cameras, Arlo Pro 2 cameras
Internet Service Provider: Aussie Broadband
Exact error message: "Your Arlo device appears offline" a minute or two after login, "This Arlo device is offline" in base station settings
The application used (iOS, Android, Web): Android, Web
Device type: Arlo Pro
Internet provider: xfinity
Error message: Your base station is offline. Check if it is powered up & connected to the internet.
Application used: IOS
Good day @mocodi,
Thanks for the message I am reviewing it now.
Back in touch soon!
ChristineT
____
Hi All,
Still offline across the ditch in Australia. Power cycled the unit already and all lights are on (green) but when I access the Arlo app it tells me the base station is offline. No recordings today either.
Model: VMB4000R3 (can't beleive you cant select this model from the Model field! POOR SHOW)
Firmware: 1.9.8.0_16666
Exact error message is "your base station is offline"
Internet provider is not relevent to this discussion but I am using ADSL.
Can you please confirm this thread is still being monitored even though its been marked active?
Thanks,
Good day @chiper,
Yes, we are still monitoring this thread. Thank you for your feedback! We have seen some other community members from your region reporting the same issue. We are investigating this further. At your earliest convenience, can you please send me a private message with your serial number?
I'll provide another update as soon as we have more details.
Kind Regards,
Christine
____
My system Base Station came back up without reboot and I can control it.
However one of three cameras is working normally now and two are showing offline. Upon 1st reboot of the base station the two offline became online and the previous online camera was offline. Another reboot swiched the status back to one online and two offline. This is really weird.
Base:
HW-Version VMB3010r2
Firmware 1.10.0.4_20963
Camera 1
HW-Version H7
Firmware 1.2.16720
Camera 2
HW-Version H7
Firmware 1.2.16720
Camera 3
HW-Version H7
Firmware 1.2.16720
Done and done 😉
THIS PROBLEM IS NOT FIXED
Thanks @chiper!
@meizydavid, I am currently working to collect additional details including base station serial numbers. At your earliest convenience can you please send me a private message with your serial number and I'll escalate your information as well.
Kind Regards,
Christine
____
I CALLED MY INFORMATION INTO SUPPORT AN HOUR AGO.
what is bad about this from netgear is we use our email to login and
you cant send us notification that there is an issue, we find out ourselves
my system has not recorded anything in almost 15 hours !
and I have to find out the hard way
what kind of quality control do you use , NOTHING
how do you put out a firmware update that causes your
network of users to go down ! TERRIBLE
I have 2 base stations and 9 cameras. Apparently, 1 base station either automatically updated the firmware or had not changed the firmware and is working fine. The other base station has not been working for about 24 hours and has been offline since. Unfortunately, it is the more important base station with all cameras being outdoors to protect my car and home. I cannot provide the firmware version as it is offline. Four of the cameras are H7 and only 1 is H3.
Before I found this topic and that others were having the same problem, I rebooted several times throughout the day without change and as of this morning this base station is still offline. I rebooted this morning as well at about 4:30 AM EST.
I am located in South Florida, USA
Now all cameras and base station seem to work correctly again. Thanks!
The web interface is now showing an additional ear icon above every camera next to battery, wifi and movement indicator. Does that mean that the cameras can record audio now?
I'm having the same problem right now here in Denmark.
My Arlo Base Station (serial: 48E5817CA29BF) appears to be off line although the leftmost 3 leds are green.
Powering off and on again does not help.
Please fix ASAP.
Rgds. Kjell
Hi Arlo Staff,
Any update/ETA when this base station issue will be resolved for good as there still are number of users suffering with this blackout?
Thank you all for your diligence in providing us further information. We are passing along information to engineering as we receive it, and they are actively working on it. We'll keep you updated.
Dawn Marshall
Community Manager, Arlo
Sorry,
The methods have disappeared. And I can no longer change the activated mode. By adding a new mode, the procedure stops when I press the End wizard button.
What can I do?
Michele
I mean that after the "Base Offline Problem", all the modes that I had created, they disappeared. and if I try to create a new one, the wizard crashes.
Michele
