Want to replace Pro with Pro 2 cameras and to have continuous recording. Paying $100/year already?
  • 1 Reply
  • 1927 Views
BShaw
so I have the Arlo Pro system but want to start replacing my Pro cameras with the Pro 2 cameras. The reason is i'm missing a lot of stuff with the basic Pro. I can see people pull up and the camera record 15 sec then nothing. don't see people getting out or anything. I want to switch to the Pro 2 so i can do a continues recording. I already pay $100 a year since i have more than 5 cameras, but i see the continues record is $100 a year also is that correct? would it now be $200 a year? Thanks for your help.
The Pro2 cameras are a little better than the Pro....
But unless powered you don't get the 'look back" feature you want
read
https://kb.arlo.com/000062042/What-are-the-benefits-of-using-my-Arlo-Pro-2-plugged-in
As to the short recordings, try not to use "record till motion stops" but pick a fixed time like 30 sec or so and increase your sense level by 1 or 2 % at a time till good response without a lot of false triggers
