Turning off an arrive/leave integration from a schedule doesn't work
  • 5 Replies
  • 2762 Views
JeffS42
Hello,
In the new App UX, I'm trying to create a schedule that turns on/off an arrive/leave (geofencing) automation.  I can tell it to:
- At 7am, disable the "Arm when I leave" automation
But it doesn't actually disable it.  How can I report this bug to Arlo?
5 REPLIES 5
You don't schedule it - you use Arrive/Leave. Create one for when you leave and a second one for arrival.
JeffS42
The app allows it to be set, but it doesn’t actually DO anything.
ANd what is set in the Armed Away mode?
JeffS42
What do you mean? What is set?
problem here is that it doesn’t actually disable these time-based schedules.
What is configured in the Armed Away mode?
You appear to be using the iOS app while I'm using Android. Perhaps there's a difference in operation/setup.
