I have a mix of Arlo wireless cams and the Arlo Smart Elite plan. It says I can have up to 20 cams, and I have 17. I can only activate 16 cams, even though 4 more activate slots are showing up, when I try to drag the 17th cam in I get an error saying "Your account does not support the addition of another device..."
What's the deal?
Hi @cellsaver
If you reboot the base station, do you get the same error message? Can you try and sign out/in and try again. Also, Is this occurring on the web portal or the Arlo Mobile App?
Yes I have rebooted all hubs, logged out and back in, but it still happens both on phone app and PC.
Had the same problem this week, contacted support, they could do nothing about it, only way to fix their broken system is for the customer to modify their account and then go back to Elite, then ARLO picks up the change and works, even though my ELITE Account said I had 20 cameras, 5 slots available. Its great how we(the customer) have to modify our accounts to fix their(ARLO) accounting system.
Your credit card will be credited back what you haven't used on your current plan and then billed for upgrading back to Elite. Again, you (the customer) have to do this because Arlo Support cannot.
animal
Arlo Q Series
detection
e911
notifications
Servicio y Almacenamiento
