Impossible to receive receipts. They stopped coming 3 months ago by e-mail, and Arlo Support is not responsive after creating 2 Tickets and following up multiple times. Why is it so hard to receive Receipts? Why there's no option to check them on the Profile?
Hi IKTHF,
Let me reach out to you via private message to gather more information from you.
Hi IKTHF,
I am facing the same issue but worse. We had not received any receipt or invoice since day 1 of subscription. Its been months. And no means to get through the my.arlo page.
Hej Jessica
Jag har inte fått kvitto sedan den 28/6-2020
Kan du sända över alla kvitton och få igång så det fungerar sen. Tack
Mvh Niklas
Konto # 36454250 Datum 6/28/2020 Faktura Nummer 2102356645 Faktureras till
Betalningsuppgifter Pris Arlo Smart Premier Single Camera Monthly - Sweden 6/28/2020 - 7/27/2020 kr 255,20 Kreditrad (summan av alla krediter) kr 0,00 Skatter Mini One Stop Shop kr 63,80 Totalt kr 319,00 Obs! Om du har gjort ändringar i ditt abonnemang under den senaste faktureringsperioden som resulterade i en återbetalning
kommer det att ta 1-2 arbetsdagar för återbetalningen att utfärdas. Ett separat kvitto skickas till din e-postadress
när återbetalningen har bearbetats.
Thanks for reaching out and sending the monthly statements, that was helpful at last. I'd recommend to suggest to the higher ups to implement the feature in the website; that is, to check the receipts. I'm sure this is a recurrent issue. Thanks.
animal
Arlo Q Series
detection
e911
notifications
Servicio y Almacenamiento
