Hi. I have had an Arlo Smart subscription for a while now (a couple of years), it always used to upload videos to the cloud (from 4 Ultra cameras). More recently I added a wire free doorbell to the mix. I have noticed for a few months now, that the doorbell videos get uploaded to the cloud but the ultra videos are only stored in the microSD card in the base station. I tried unsubscribing and resubscribing but it makes no difference. Thoughts?
Hi. I have had an Arlo Smart subscription for a couple of years now. It used to work fine for my 4 Ultra cameras. I have more recently added a wire free doorbell to the mix. Now only the doorbell videos get uploaded to the cloud. The Ultra videos are only found in the microSD card in the base station. Why is this happening? All cameras are enabled for the smart subscription. I recently tried unsubscribing and re-subscribing to no avail.
@doncarajo wrote:
Now only the doorbell videos get uploaded to the cloud. The Ultra videos are only found in the microSD card in the base station. All cameras are enabled for the smart subscription. I recently tried unsubscribing and re-subscribing to no avail.
Can you try making a manual recording on one of the ultras, and see if that shows up?
Are you using cloud activity zones on the Ultras? If you are, maybe try removing them, and see if that resolves it. If it does, then you can try recreating them.
This appears to be a duplicate (best not to post your issue multiple times). I replied on your other post.
Yes, sorry about the double post. After I submitted my browser crashed and did not appear to have saved my post. So I typed it out again.
In any case, I will try what you have suggested, thank you.
animal
Arlo Q Series
detection
e911
notifications
Servicio y Almacenamiento
