I have 2 Arlo Essential Spotlight cameras and 2 Arlo Pro 2 cameras. The battery on one of the Arlo Pro 2 cameras died even though I have a solar panel connected to it. So I took the Pro 2 and both essential cameras down to charge and replace the battery. Since doing this, I have lost all videos for these cameras back to July 20th. There are a few videos from August 7th that I really need to retrieve if at all possible. According to the Arlo support representative I communicated with a while ago, even if the battery died, the videos should still be in my library. Any help is greatly appreciated!
Did you have a subscription for the Pro 2 cameras?
Did you remove the cameras from your account when you tookl the cameras down?
They should in fact still be in the library, though you might need to re-add them to the account if you removed them.
Thank you for your reply. That could very well be my issue. The videos for both of the Pro 2 cameras go back to August 10th. The videos for the essential cameras go back to July 20th; however, there are days here and there where there are no videos. I was on the trial for the Arlo Smart plan with the essential cameras. I have since subscribed to the Arlo Secure for all of my cameras. Again, thank you!
Arlo Q Series
e911
Servicio y Almacenamiento
