Is the Smart trial per camera or Smart Hub?
  • 2 Replies
  • 3428 Views
sam2021
HI
previously bought 2 x Arlo Pro 3 camera's which came with a 3-month free smart trial and it ends mid April 2021
Just bought 2 x Essential XL cameras which also come with a 3-month free smart trial and ends mid June 2021.
My question is can I move my Pro3 cameras onto my second trial so that I keep everything together? If so how do I do that? I went into settings > subscriptions>manage but couldn't see an easy way to do it.
thanks SAM
dcfox1
The trial is per camera under the trial. You can't combine expired trial cameras, you will need a subscription for them. You can get an individual sub for the pro 3's in April when they expire.   When the Essential cams trial expires in June the 5 camera plan would be cheaper to add all 4.
dcfox1
sam2021
thanks for taking the time to reply, much appreciated 😀
