  • 1 Reply
  • 2316 Views
rseward
I have some of my Arlo Security Lights set to trigger a camera when the light detects motion, and that works great, I get the recording and all is good.
Here's the thing... I subscribe to Arlo Smart Premier and one of the features of this plans is "Enhanced Notifications" and/or "Rich Notifications" which does not work if the Arlo Security Light is triggering the camera, because instead of getting a notification from the camera I get a notification from the light.
Is it possible to get the notification from the camera rather than the light when the lights motion sensor is used to trigger the camera rather than the camera's motion sensor?
JessicaP
Hi @rseward,
If you would like to receive a enhanced notification for your camera, you will need to arm the camera instead of using cross-triggering with your Arlo Security Light and Arlo camera.
