E911 Invalid Address Error
  • 1 Reply
  • 3135 Views
FrenchieGuys
I am trying to set up our e911 service on our camera system and regardless of what device I use, it continues to tell me that my address is invalid.    Can someone please help me as our address is valid.
Thank you.
You need to contact support on this:  https://www.arlo.com/en-us/support/contact.aspx
Normally when you call 911, the telephone network automatically routes the call to the PSAP (Public Safety Access Point) that handles your location.  The PSAP then takes the call, and dispatches any needed emergency services.
With the Arlo e911 service, that won't work - since the goal is to call your home PSAP, no matter where you happen to be. So the Arlo back-end uses your address to figure out what that PSAP is, and then calls it directly.  In your case, they aren't finding your address in their database.  They'll need to work with their provider to sort that out.
