Do I need to install all of them and cameras again if I buy Arlo Smart Plan Elite?
Hi, I have 3 systems with Arlo Pro 2 VMB4000 base and 14 cameras..... Do I need to install all of them and cameras again if I buy Arlo Smart Elite and I want to have evrything in one profile? All of them are in a different nettwork..... M.
If the systems are on different accounts then Yes... more then likely you must remove two systems and move them over to the new primary account
I'm in the same situation. I want to go to the Elite plan but I don't want to sync all the camera again. I see in the settings/profile there is an option to change the email. Can I change the 2nd account email/password to the primary subscription email? Would that work?
Changing plans simply changes plans. It doesn't reset your system.
For that you need to remove all devices from Setting, My Devices in your second account before you can set them up in your primary account. No way around it. Make notes of settings, modes, rules and schedule before removing them.
animal
Arlo Q Series
detection
e911
notifications
Servicio y Almacenamiento
