  • 4 Replies
  • 4061 Views
  • 2 Likes
ManuelGuerra
Hi there,
I have a system with two bases, 5 Arlo Pro cameras and 1 Arlo Q. I was planning to get at least two more cameras.
I don't absolutely need all the cameras running the whole year, there are some months on which the free no subscription option would be just fine for a core number of 5. Is it feasible to consider opting in and out on a plan thoughout the year, according to my needs?
Thanks for the help.
You can do the plans on a montly basis , tho it does costs just a bit more than the full year.
And you can cancel/change at any time, getting a pro-rated refund.
ManuelGuerra
Thank you for the kind answer! That's great that it is possible to do so!
ManuelGuerra
Great! Thanks a lot!
