Base station unavailable for remote access
  • 2989 Views
Lofidelityallst
Can’t access base station recordings remotely after the update.
reconfigured the port forwarding on the app and router still no luck. Trial recently ended with another ultra 2 camera xl. These glitches are getting annoying. Fix the problem Arlo!!
WHat base/hub? Only the VMB4540 and 5000 SmartHubs can use the app to view local recordings.
Have you verified the base/hub's IP address and configured the router to assign a static IP address to it?
Lofidelityallst
I sure have. I haven’t tried a factory reset yet
Lofidelityallst
Factory reset solved the issue.
