  • 1514 Views
Rhannon
Any clue when all 3 cameras will actually sync?? Seems like a scam when only 2 of the 3 cameras will sync.
and yes I have callled support multiple ttimes and they have done nothing to help...no wonder their is a dscount...only 2 lights actually work..
Rhannon,
What behavior are you seeing when trying to sync the third light? Does anything happen when inserting the battery?
Rhannon
Blue light blinks as it is supposed to , and the Bridge flashes Blue as it is supposed to...however it times out ..over and over repeating the process
Rhannon,
Try plugging the light in using the AC adapter and power cable that came with your kit and then try the sync process again. Do you experience the same results?
  • 1515 Views
