any way to disable notifications during the day?
  • 1 Reply
  • 1544 Views
honestabe
I just setup the security light, but I'm receiving some false notifications of motion. (I assume I have to mount it better?) Does this mean that the Light is turning on during the day, or only letting me know about motion? I have it setup to trigger recordings on 2 different cameras if the Light detects motion -- does this mean it will only trigger this rule when it detects it's nighttime? Or is there any way to customize the time of day it will work?
JessicaP
Hi @honestabe,
For receiving false notifications, do try to reposition the Security Lights and see if that'll make things better.
Whenever you're receiving notifications from your Arlo Security Light, it'll notify you that motion is detected. If you want the Security Lights to detect motion during the evening, you can use "Schedule" mode or use the "Dusk to Dawn" sensor, which you can read more about it here: What is the Dusk to Dawn sensor setting on my Arlo Security Light?
  • 1 Reply
  • 1545 Views
