Third Arlo light not connecting
  • 2 Replies
  • 2070 Views
Shansnsn
Hi I simply cannot connect my 3rd arlo security light the first two connected fine,
,This one will not.
I tried everything possible put in new batteries and everything else.
I’m going to have to return this to my local store.
Please help.
Shansnsn
Anyone available?
brh
@Shansnsn
I just installed 6 of the Security Lights, but I am not an expert on them. It is possible that the unit is defective. I have had a couple of instances when after installing one, nothing worked. I removed the battery and made sure I really pressed it back in, then the light started working. Try swapping batteries with one that connects. Are you seeing the light flash blue while trying to connect then turn green once it has connected?
Brian
  • 2 Replies
  • 2071 Views
