Two of three security lights do not light at night when it is dark
  • 1 Reply
  • 1124 Views
kearyk
Two of three secuirity lights do not light at night when it is dark.  The motion sensors go off, and the lights can be turned on my the switch in the app, but they do not go on at night with motion.  Not sure what is going on.  This started after the latest app update.  Thank you.
Check your active mode to ensure the proper one is set. It might be worthwhile to reboot both the base and the bridge.
  • 1 Reply
  • 1125 Views
