Top 10 Reasons to Love the Arlo Security Light
BretD
  1. 100% Wire-Free Set-Up
With no power cords or wiring hassles, you can easily mount your Arlo Security Light on walls, eaves, gazebos, and more, anywhere around your home, so you are not bound by the power source, but by where you want the light directed.
  1. Smart Controls with Arlo App
With the free Arlo app, you can control and automate Arlo Security Light from anywhere, and automatically receive instant alerts to your smartphone or email when it detects motion.
  1. PIR Motion Detection
You can set the sensitivity level for Arlo Security Light to turn on automatically when the PIR sensor detects motion, and even get motion-activated alerts without having your lights turn on.
  1. Weather-Resistant
Arlo Security Light is IP65-rated, making it ideal for outdoors, rain or shine.
  1. Customizable Light Settings
Adjust the colors and patterns (spotlight, floodlight, flashing) of your light for specific situations, and group together multiple lights and easily synchronize patterns to turn on/off together.
  1. Scheduling
Schedule the Modes for your Arlo Security Light to turn on when sensing motion to discourage would-be burglars and give the illusion that someone is at home.
  1. Arlo Integration for Enhanced Home Safety
When movement triggers the Arlo Security Light to turn on, your Arlo Security Cameras can be configured to start recording so you can see the activity or have additional lights turn on.
  1. Smart Home Integration with Amazon Alexa® and IFTTT
Use simple voice commands with Amazon Alexa to turn your outdoor security light on and off without lifting a finger. Arlo Security Light works with other IFTTT-compatible smart devices to create endless possibilities for safety and security.
  1. Rechargeable Battery
Long-lasting, rechargeable batteries take the expense out of uninterrupted security lighting and for added convenience; the optional solar panel accessory can keep the batteries charged indefinitely.
  1. Outdoor Mount
Easily adjustable mounts provide a 360-degree swivel and a 90-degree tilt for the perfect lighting angle when securing your Arlo Security Light over your door, porch, tree, and more.
____
Please click KUDOS or REPLY If you found this helpful.
82 REPLIES 82
jlpowell84
@jguerdat yes I am finding about 5 seconds as well.
Is there a way to make security lights ignore a car like a camera can?  I'm wondering why my lights at 60 motion sens is detecting every car over my cam at 100.  They are 4ft apart facing driveway.  Light is directed more straight down driveway while cam is angled.  BUT!  the cam in it's first location was angled much more drastically AWAY from down the driveway, you could see end of driveway and road on VERY EDGE of frame.  Then when it was at a more drastic angle the cam picked up EVERY single car.  Now not a single one.  Yea I dont want it too and will use rules to do so but dont have it set to ignore cars now, not picking any up.  Just seems this one cam is not working well...
Why not have the camera trigger the lights in the camera modes and rules? That way the light position can be whatever you want with the camera causing to turn on.
jlpowell84
You mean like lights ONLY come on when camera is triggered?
Unifi UAP 3 piece wifi extending/enhancing system arriving tomm.
The lights I do have positioned exactly where I want them.   One is on porch lighting up entry way with front door cam.  Other two are out on corner of house (one on each side of corner 3-4ft from corner) near Driveway cam.  All three of these devices are pointed at my truck/trailer but cam records entire driveway, can see street and more as we know it has wide frame.  The lights both point right at tool area so I dont really want to reposition but now after power cycle those to lights are coming on with every SINGLE car that drives by.  Batt are like 40% already...
Some creative thinking may be needed to find the solution.
jlpowell84
haha lol!  Can you tell me are the light motion sensors the same hardware and or function the same as the cams?  I'm just wondering if I placed one light in a little tree on other side of trailler(8-10ft) and pointed directly at trailer it would still have edge of frame catching street.  But thats if the light motion sens is like cams.  I guess one needs to have lights pointing back to property away from street lol!
Surely many people here have lights mounted on homes pointing out to property?  This seems rather trivial lights would trigger cars EVERY TIME 65-100ft away.  I have measured, it takes a full 50ft power cord plus two 20ft to get my electric leaf blower to end of driveway.  Even light motion sens of 32 was still catching cars...
Or maybe use non arlo motion light to light up truck/trailer area and use arlo lights elsewhere...
I can't say if the detectors are the same between the cameras and lights but surely are similar. The big issue is that cars and trucks are much larger IR sources than people. The system is designed around person detection so positioning is potentially critical. Have you read the FAQ here on camera positioning? It would be similar for the lights, too.
Dtc123
400 lumens. Same battery.
superic
Please tell us the new light system can connect directly to the base station.
If no, Please please please fire the designer and product manager ASAP! That is just STUPID!
