Security light battery
  • 1 Reply
  • 2021 Views
Inspector8
How do you know if battery is charged? Does it show a blue light like the camera? I paired them up to the bridge but unplugged everything. Then wanted to charge up batteries.
ShayneS
Hi @Inspector8
The security light does not illuminate any Light/Blue LED when fully charged or charging. When the security light is less than 100% charged when you plug it in, the charging logo on the devices screen will have an empty battery/transparent with an outline & the grey charging bolt. When the battery is fully charged the battery logo will be full/grey with the same bolt Icon. You can also determine your devices battery percentage in the devices settings page. Settings > My devices > Device Settings.
  • 1 Reply
  • 2021 Views
