Security light and Essential outdoor cam won't work together
  • 4 Replies
  • 1981 Views
ChicagoRay
My Security Light and my Essential Spotlight Camera (gen 1) individually work as they should, but the option in the App to have one trigger the other are grayed out and I can't choose it. The Light and Camera and Bridge are all installed and visible in the Arlo Secure App. The app and all the firmware are all the latest version. Is there a solution to this problem?
That may depend on whether you see Library to view recordings or Feed. The new user interface (UI) may not support this as the security lights have been deprecated.
ChicagoRay
Yes I can view all the recordings in the feed. But in armed mode I can't add a rule to have the camera turn on the security light when it senses motion, or vise versa. The little built-in light on the camera turns on, but the security light instructions say it can work in tandem with the camera. It doesn't seem to be in the app anywhere.
My recollection is that one of the (many) issues with Feed is that it doesn't fully support the security light yet.
ShayneS
HI @ChicagoRay
Thank you for the feedback. Was this feature working before you migrated to the latest Arlo experience with the "feed" tab at the bottom of the app.
  • 4 Replies
  • 1982 Views
