Security Light will not sync to my bridge
  • 6 Replies
  • 4200 Views
Consideritdun56
3.2.51 so apparently after your firmware update in December my motion detector lights will not come on nor sync to the Arlo Bridge in the beginning it was flashing amber and blue looking up in your support app it said it was doing a firmware update. Sooo after 2 days its never synced to the bridge I reset and reset and deleted and restarted over again tooo many times called support to nooo avail and these devices are tooo expensive to be experiencing something like this. Sooo any suggestions??? The error message says my motion lights are off line, I read somewhere someone said the GH should be 2.4 which it is
6 REPLIES 6
ShayneS
Hi @Consideritdun56
I see your lights are online, are they just not detecting motion at the moment?
Consideritdun56
That’s correct, as well as in my settings it says the bridge is off line, no blue light is lit on the Arlo bridge I’ve reset a thousand times and yess it on Bluetooth and yes 2.4GHZ whyy after the firmware update does it have to knock things out!
ShayneS
How long have you had your bridge and security lights?
Consideritdun56
I purchased this pkg back in mid November , now I also see there was another system update you guys did yesterday Friday mid-morning
Question, the Arlo Bridge is it supposed to have the blue light aluminate always? It’s should stay lit correct? Which mine does not, it’s plugged in but no light on it
Consideritdun56
Arlo app settingsArlo app settings
Phone settings in ur Arlo appPhone settings in ur Arlo app
Arlo settingsArlo settings
See photo
ShayneS
Hi @Consideritdun56
I would suggest contacting customer support again, since you are still within the warranty time frame. Arlo Tech Support
  • 6 Replies
  • 4201 Views
