Security Light Bridge Doesn't Find wifi
  • 7 Replies
  • 7063 Views
  • 3 Likes
JDJS
I have spent several hours on attempting to get the bridge for the security lights (bought a few days ago at Costco), to sync up with my wifi.  I have a dual band (2.4 and 5) xfinity modem/router.  I have an open ticket with Arlo currently.  Arlo suggested I contact Comcast to get my dual band router to separate my bands with different SSID's/passwords, etc, because the bridge cannot recognize the 2.4ghz band because it's "broadcast dually".  I've never heard of this with any other item I've had to sync with my wifi.  I follow the setup instructions for the bridge, I get to the part on the Arlo app where the bridge setup is searching for wifi.  It never finds my wifi or any surrounding wifi signals from my neighbors (which most other things will find several).  I try to manually enter my router wifi information and still, nothing.  The bridge blinks blue, then after some time, goes back to blinking amber.
Has anyone here had this issue and have had luck in resolving it?
JDJS
No, I only have iOs devices.
*************But, I wanted to share with you and anyone else who may come across this.  I was able to get it set up finally!  I noticed that on the bottom of the box that the lights/bridge came it, was the MAC address.  I logged into my router and there was a section where I could manually add a device.  So, I gave it a shot, I gave it a name and entered the MAC address, hit save.  I then reset the bridge and restarted the setup from the Arlo app.  BAM!  Money.  It worked!  So, now I'm good to go, after hours on the phone with Arlo and no resolution.
7 REPLIES 7
ShayneS
Hi JDJS,
Which phone are you using to setup your Security Light Bridge? Are you using an Android or iOS device?
JDJS
I am using iOs.
ShayneS
JDJS,
Do you have an Android device you can try the setup process with?
JDJS
Do you have security set up on your router to prevent unknown devices from connecting (MAC address filtering)?
Kelletp
Do your push notifications work?
JDJS
  • 7 Replies
  • 7064 Views
  • 3 Likes
