Rubber cover on the bottom of the light does not want to stay closed
  • 5 Replies
  • 3668 Views
  • 3 Likes
EdwardNNC
Does anyone else find it difficult to keep the bottom rubber cover on?  Mine keeps popping open.
I might need to tape it closed.
5 REPLIES 5
Just had this on a camera. I took a small screwdriver amd cleaned out the inside of the plastic plug cover. It took a bit but it cloese/seals now.
EdwardNNC
These are brand new lights.  I have not even put them outside yet.
The camera covers seem to be ok for me so far.
You can push them on as hard as you can, and within minutes, they pop out.
I think I am going to gorrilla tape them shut.
johnboydavis
Same problem with mine. Bit of tape worked for me
Just make sure the plug is fully inserted and the tape is fully sealing all around the plug.
EdwardNNC
I agree... and I did (before you message, but I do appreciate it!!)
I went with the white gorrilla tape.
  • 5 Replies
  • 3669 Views
  • 3 Likes
