  • 4 Replies
  • 2015 Views
GerardvR
Hi,
Here’s the thing:
My Arlo security lights are controlled with the Bridge.
My Arlo cameras are controlled by the Base station.
They work seperately but should work together obviously.
I set the system up and configuered everything with the Bridge. So the cameras activate the lights, within the planning.
My question:
How to set up the system on the Base? Leave everything blank?
I do not want the two systems to conflict....
Any reccommendations?
They were designed to work together so no issues...
The Bridge will end up showing just like another base in your Settings.
You can create custom modes so the cameras can turn on lights or lights turn on cameras...your choice
GerardvR
I understand. The thing is:
I have configured the comple set up in the Bridge, including a time table.
So what setting do I choose in the Base?
Now I have choosen ‘Planning’ but I did not set any. Otherwise the time tables set in the Bridge may conflict with those set in the Base.
Hope this makes any sense 😅
If you mean your running schedule for the base and the bridge... make sure they run the same times.
GerardvR
That’s what I meant.
I will sync the schedules.
Hope for an update in which they will be integrated.
Thanks!
  • 4 Replies
  • 2016 Views
