How to have Arlo Security Lights to turn on at night when motion is detected?
  • 2068 Views
Todd6640
We would like our security lights to turn on at night when motion is detected. Right now we only get notifications. I’m assuming there is a setting to make this happen but can’t seem to figure it out. Help???
Streak2
Master Master
Go to modes.
Select your light bridge, armed and then on a per light basis check the rule for each one to make sure that it turns on when motion is detected. This should have been the default when you installed them.
michaelkenward
Sensei Sensei
Sensei
Are these Arlo lights? Or some other make?
Just another user
brh
@Todd6640
Usually you have to wait until the following day for the latest firmware to load and take effect. The latest firmware has a Dusk to Dawn feature that allows you to set the darkness threshold that you want the lights to trigger at.
Brian
  • 2069 Views
