  • 6 Replies
  • 5967 Views
  • 4 Likes
Nighthawk9988
Hi there
I am most interested in buying the Arlo Pro 2 bundles but I can’t get the upgraded version 1080p within Australia so I thought I could buy from overseas. The only problem I am worried about is that I can not charge the batteries from my AC power outlet because we use 240v in Australia and not 110v and fear that I will blow the charger up. Can I use overseas version in Australia?? Does it have a transformer for multiple voltages?? I hope you can help me
Kind Regards
David
The adapter for ac that I'm looking at right now shows an input of 100-240v
This was in the Pro2 box I received
6 REPLIES 6
brh
@Nighthawk9988
I believe that the Arlo Pro 2 comes with a universal power adapter that will work on 240V AC although if your outlets are like the ones in the UK, you will need a travel adapter to make the pins work.
I don't know which is better, purchasing from USA or UK.
Brian
Nighthawk9988
Thank you very much for the info!
Nighthawk9988
Thank you for your help advice as well! Now I have to decide whether I should buy from the US or the UK. Either way I will need a travel adapter to suit AUSTRALIA pin
Nighthawk9988
Thank you so much Brian!!!
Kpatel7899
  • 6 Replies
  • 5968 Views
  • 4 Likes
