  • 1 Reply
  • 1221 Views
DDBeach
I'm on my second set of Security Lights from Costco. Same problem. Connects to Nighthawk router, but lingers on connection screen and then blinks purple.
Please help. Do I need to return for a 3rd pair? I also have 4 Arlo Pro cameras and haven't had any issues.
JessicaP
Hey @DDBeach,
If it is blinking purple on your Arlo Bridge, it means that it is connected to the WiFi network but cannot connect to the internet. Try to check and make sure that your router can gain access to the internet.
  • 1 Reply
  • 1222 Views
