  • 2 Replies
  • 10028 Views
ccranis
Just to double check on something.
I understand you can set this as a motion sensor light, but can I also just turn it on and off at will with the app? I assume there is an on/off button in the app?
Yes.... button in the app with default time ( you can change )
Light has a motion sensor and can also trigger a camera to record ( or opposite, cam can trigger light )
pietrzej
@ccranis
Hey,
Yes you can turn it on and off within the app. You can also set brightness and time the light stays on for you can also set/change the colour of the light including rotating multiple colours at 2+ seconds intervals.
You can also change the beam of light wide and narrow!
  • 2 Replies
  • 10029 Views
