Arlo Security Lights not turning on lights but works in test mode.
  • 1 Reply
  • 2384 Views
alexmcleaniii
I have two lights. Both lights work in test mode. Both settings are the same for Dusk to Dawn set to Bright and the Motion sensitivity is set to medium (I also tried Hight).
Camera #1 doesn't show motion detection in the app.
Camera #2 shows motion detected in the app but still does not turn the light on.
The Bridge framework is 2.0.1.0_267_230 (not update available).
ShayneS
Hi @alexmcleaniii
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
  • 1 Reply
  • 2385 Views
