  • 1 Reply
  • 3055 Views
ryanhurst39
Notice that the batteries can’t last a months with all the movement in my neighborhood. Does anyone has a recommendation for outdoor usb cable? The location and shape of the USB port is different from the Arlo Pro cameras which makes me doubt the same cable.
There's a solar panel listed for the lights which may be useful. I haven't tried an AC adapter but other than the exact shape of the surrounding plastic on the cable there's nothing unusual about the port. You could shave the plastic surround on the cable to allow it to fit or use a cable with a smaller surround.
  • 1 Reply
  • 3056 Views
