Arlo Security Light does not stay on for more than 20 seconds after triggered by motion at night
  • 2 Replies
  • 3057 Views
RCCola
Arlo Security Light does not stay on for more than 20 seconds after it is triggered by motion at night.  Is anyone else having this problem?  Armed Arlo Security Light to trigger camera on motion detection, that seems to be working, however, the light is supposed to stay on for 100 seconds, but only stays on for 20 seconds.  This is the case for 2 Arlo Security Lights I've set-up.  Not sure how to configure the lights to stay on longer with motion detection.
It appears that your rule for the light is set to 100 seconds - is that correct or is it set to the default time? If correct, you might want to create a new mode with identical rules to test. Removing the bridge from power and plugging it back in may help, too.
RCCola
Hi Jgerdat,
I set the rule for the light to turn on for 100 seconds in the Armed mode.  However, was not working.  I did try as you suggested to create a new custom mode with identical rules and that seemed to work, so I'm using that now, thanks for the suggestion!
  • 2 Replies
  • 3058 Views
