Arlo Light bridge doesn't connect to Eero network
  • 1 Reply
  • 3817 Views
  • 1 In Conversation
B2020
I bought a new Eero mesh router setup and was able to get my Arlo security cameras reconnected through the base station, but the bridge for my lights won't connect.
I go through the setup process but it keeps failing. While it was in the process of syncing, I switched over to the Eero app and saw that the bridge was listed among the connected devices, so there must be some kind of connection happening.
When I tap the bridge in the Eero app to see the details, it says that it's using the 2.4GHz connection.
Any idea what's wrong? I've tried removing the light bridge and setting it up from the first step in the process, but that hasn't worked either.
Thanks.
B2020
Never mind -- it finally connected after a few tries. I had to re-add the lights too, and that was a bit of a chore as well.
Setting up the Eero was a lesson in how to do hardware setup right. I've always found Arlo to be a bit lacking in that department.
B2020
  • 1 Reply
  • 3818 Views
  • 1 In Conversation
