  • 2 Replies
  • 1910 Views
cooper1954
New Arlo Bridge does not turn amber, nor connect to wireless router.
JessicaP
Hey @cooper1954,
Could you clarify of the problem you are having with your Arlo Bridge when it does not turn amber? Is this after you plugged in your Arlo Bridge to the outlet and waited for a few minutes?
cooper1954
The amber light never came on after plugging it into the outlet.  I replaced the bridge and now it works fine.
  • 2 Replies
  • 1911 Views
