Why am I getting notifications
I’m paying the extra for Arlo secure, and I have set my camera to only notify on smart detection. And I have set activity zones… so why yo I get constant motion notifications. And detections on things outside of the detection zones
NZspy,
It's important to note that Smart settings only apply to push notifications, you will still receive recordings for motion from objects not selected within your Smart notificaiton settings.
If you're getting motion detection outside your detection zones, you might consider adjusting your cameras position or reducing sensitivity until you achieve the desired results.
So how can I set it up so that I only get smart notifications.
Go to settings-smart notifications to select the options for smart on each cam.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
