  • 23 Replies
  • 6749 Views
  • 3 Likes
Kiwiarlo
How do I check/change time zone within the latest app? My recordings seem to have the wrong time stamp. And "feed" not showing today's (early morning) recordings
Kiwiarlo
My version is 6.4.5
My issue seems to have been finally resolved! Likely over 2years since I've been able to view motion recordings in the same morning in which they were recorded. Please update the team looking into this that they dont make any other changes that'll affect this issue reoccurring.
Many thanks to whoever finally sorted this
23 REPLIES 23
  1. Are you seeing "Feed" or "Library" in the app menu?
  2. Did you enter an address for your location?
If "Feed" and "Yes", then the system sets your timezone automatically based on the address.  There is no setting to override that.
You can try changing the address and changing it back.
Try making a manual recording to confirm that the timezone is correct.
Kiwiarlo
Hi there, I'm seeing "feed" just made manual recording and popped up straight away as correct time but then disappeared only showing yesterday's recordings. Before app update lastnight I was having same issue and the old app showing "library" wouldn't update current days recordings until after midday, I'm thinking was a wrong time zone set. Managed at some point lastnight to find and set to my location but still not working and can't remember where I found that to check location settings are still correct
Select the profile icon in the upper left of the app (or web page).  Then select "Home"
Kiwiarlo
Many thanks I found this by fluke in my lunch break, once set location label and address it wanted me in sync base station and cameras but wasn't home to continue this then thought I'd lost the lot until I arrived home and got the notification. Address set and app/cameras all set up so should be working correctly now will find out tomorrow morning if the feed updates straight away with motion recordings. Fingers crossed. Thanks again for your help. Will update tomorrow when I gets chance
Kiwiarlo
Update this morning, triggered camera leaving this morning, but entering "feed" there is still no recordings for today, curently 730am. Have just double checked my location settings and address us set right and timezone correct as well but seems to be a long delay before AM recordings are viewable in "feed" (same issue for about a year now with old app via "Library") as previously said factory reset base station only other day as well. Any ideas? I'll try update in my breaks at 10am and 1pm. Previous tests have shown no "Library" updates until after lunch. Thanks in advance
Kiwiarlo
2nd update, still no feeds for today's date, as expected. Will check again at lunch and expect by noon all today's recordings will appear.
Are you located in NZ?  There were some reports of folks in Australia and NZ seeing this problem, but I thought that had been resolved.
I'm tagging the mods - @BrookeN , @JamesC , @ShayneS
I misunderstood your earlier posts - I didn't get the "recordings show up at 12 the following day" symptom.
Kiwiarlo
Yes I'm in NZ I spoke with someone from arlo support maybe a year ago and they walked me through the long drawn out process of base and wifi reboot etc all of which I'd tried myself and nothing changed they said they'd get back intouch and never did then seen my report had been marked as resolved and trying to contact again says I'm no longer available for arlo support... update again now after 1pm and all today's "feeds" are now showing fine as they should. Only 5hrs late if I needed to view triggers of a burglar onsite.. makes them kinda useless huh.
If anyone has had issue and resolved please let me know how... would be very much
appreciated
BrookeN
@Kiwiarlo Do you mind sending me screenshots of what you are seeing. And also so the development team can look into this further we would like you to generate some logs for us. Are you using an Android or a iOS device?
Kiwiarlo
Hi there I'm using android.  Note today's date 25/7/2025 1030am 4x missing feeds.
AikaneKai
Luminary
Luminary
I'm not sure how this got marked as resolved when it clearly isn't.
Anyway,  this sounds very similar to this issue.
Was this ever resolved?
BrookeN
@Kiwiarlo can you also send me a screenshot of when you get the motion alert but the event is not captured. Does it very when you end up receiving the feed videos or is it a certain time?
Kiwiarlo
I think my previous screenshots showed pretty clearly that I had "unseen feeds" and the "feeds" didn't even show that date. I can't be exact but it's always around midday I can finally review the feeds from the last at least 5hrs.
Sorry I'm not going to stay up all night triggering cameras and checking if I can view the feed or not, I originally spent big money on this set and expect what it states on the box is true and manufacture support should be on-going for the life of the product
BrookeN
I have sent all this information onto our development team. They are currently investigating this behavior. I will reach out as soon as possible.
Kiwiarlo
Just updating with as much info as possible,  no updated feed checked at 1201pm then after triggering motion at 1208pm and checking feed was all loaded upto date. I'm assuming mine could be the opposite 12hrs delayed to another post (possibly 12hrs different in timezone) mine being after midnight til midday no updates to feed. Midday to midnight works fine. Thanks for helping looking forward to having sorted soon 🤞
BrookeN
I just wanted to reach out and let you know this is still currently being looked into. I will update you as soon as possible.
Kiwiarlo
Thanks for update, just came on to check-in, thought maybe had been forgotten about, started work early and can confirm issue still current and home just after 12pm and feeds all loaded.
Please keep updates coming atleast weekly if possible.
BrookeN
Hi, I just wanted to give you a quick update. This is still being looked into and I will reach out as soon as possible.
BrookeN
Can you please check if you are on Android 6.3.8. And if you are, can you see if the same behavior is seen?
Kiwiarlo
Couple months on this thread now and still no resolution... android version for device or what? How would I check this? Seems the issue with everyone experiencing this is across multiple devices/platforms. Seems there's no help and best bet to chuck the lot and try elsewhere..
BrookeN
Are you updated to the 6.3.8 version?
Kiwiarlo
My version is 6.4.5
BrookeN
Thank you for the update. I will let the team know that you are no longer seeing the behavior.
