Secure Plus multiple locations
  • 1 Reply
  • 2574 Views
Theoak_1
I have 8 arlo pro 5 cameras ordered. I want to use 4 at my house and 4 and my business which is 100m away. Both locations will have wifi access. Can I use a secure plus subscription to view all 8 cameras at both locations
If you choose to set up the system with two locations, then you will need two subscriptions.
You can set it up with only one location to avoid that.  The downside is that   you only have limited control over the cameras, because there are only 3 modes for each location.  If the cameras at one of the locations are on 24/7, then that will probably work out ok.  But if you want different schedules for the two locations, then it probably won't work.
FWIW, I expect Arlo will add back the custom modes feature, since it is quite clear that many users need more than three modes.  So you might start with a one-location setup for now, and see if that is workable.
