Record & Notify
  • 12 Replies
  • 2599 Views
Edinburgh_lad1
Morning (in the UK) @ShayneS
Thought I'd report another issue. Steps to reproduce:
- go to Routines
- use any mode
- select Add Device Rules
- add a camera *and* select (ensure) the toggle for notifications is 'off'
- save changes
Even though the toggle was off, the new device is set to record *and* notify. Only once you repeat the above steps but with the device already added, you can then set the status not to receive notifications.
I'd also like to ask about the progress of resolving one of my other problems: I can't update firmware on my old base station and I can't add any cameras to it. Needless to say: I'd like this issue to be resolved pronto as I can't use Arlo that I've already paid for. If not possible, please organise for a new SmartHub as a replacement. Thank you!
ShayneS
Hi @Edinburgh_lad1
To help with the symptom you were experiencing with notifications, the team enabled your account for the new experience and custom modes. Moving y0ur account over to this should help with the issue. Can you verify if you have the new feature available within the routines tab?
12 REPLIES 12
ShayneS
@Edinburgh_lad1
Let me test this symptom with the notifications and get back to you. Also, please bump me on the thread you have open or apart of for the firmware concern. I am following that one and will provide any new info in the thread.
ShayneS
I am still looking in to the symptom you reported. Does this only occur for your Ultra cameras? I was testing with other devices and was only able to reproduce a similar symptom with ultra only.
Edinburgh_lad1
Thanks. Arlo HD and Pro 2, too.
ShayneS
Thanks for that. Also, when this occurs, is it just a visible issue or when turned off does it still send the push notification?
Edinburgh_lad1
I'll test and let you know.
In the meanwhile, @ShayneS , I've discovered yet another issue (not kidding you, tough you're probably used to issues with Arlo here and there):
- select SmartHub, then you should be on 'Device info', where the product type is listed, location and firmware etc.
- choose the go back arrow (top left corner) - you'll get onto the 'Device settings' screen
- choose the go back arrow again (top left corner) - you'll then somewhat miraculously end up in 'Settings'
Also, what is causing the Dev Team to create these problems every time there is a software update of some sirt? Can you tell me? I can take a lot, you know 🤭 - I'm ready for the worst truth...
ShayneS
@Edinburgh_lad1 thanks for testing that
It looks like someone from the team is looking into the second symptom you reported. In the future, if you can please create new threads for any symptoms you might have so We can track them accordingly and I can provide you the best support possible. You can tag me in any new threads and I'll be sure to reply.
Edinburgh_lad1
Sure. Sorry for that.
As regards the first issue, it's not just a visible thing but it does send a notification when it's off. I just tested that with Arlo HD.
ShayneS
Hi @Edinburgh_lad1
Edinburgh_lad1
Gosh @ShayneS , I forgot about this one. I only posted about this because I had come across it and thought it would be worth mentioning.
I don't actually use custom modes, so no bother if my account is not moved onto the new version.
Thank you, anyway.
ShayneS
Oh okay, I'm fairly certain they've placed your account on it already. You should be seeing the custom mode feature. I can request they remove you if possible?
Thanks for the update.
Edinburgh_lad1
Hi @ShayneS
There is no custom mode available in my app yet. But no worries about that. As I said above - I don't use a custom mode and have no immediate plans to do so. However, if they've already placed my account on it, that's ok.
The issue described in this thread had arisen while I was installing/re-installing a camera so it was only for the dev team's attention that that was the issue with notifications.
ShayneS
Okay thanks for the clarification. I'm going to close this thread now. Please let me know if you have any other concerns. You can start a new thread and tag me, and I'll be sure to reply there.
