Question about business plan
I subscribed Business Professional Plan.
I saw description of this plan. it is described that up to 24 cameras and 30 days of video playback.
But it support only play history (like, motion detect video clip), I would like to use video playback function.
is Business plan support only video clip? or support full video in 30 days?
Business plan description:
Let me double check on this for you. I'll provide an update as soon as possible.
The plan you have selected in the screenshot supports up to 24 cameras and 30 days of video playback. For the Smart features, you will need to add the Smart Add-on.
@RaymondKim: Are you asking if the plan includes continuous video recording (CVR)? If so, @ShayneS didn't really answer your question.
I believe the answer is "no", and that you would need a separate subscription for that. But I don't use that plan, so hopefully one of the mods (or someone who does use it) will respond.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
