When I view the live feed for any of my cameras on v4.7_28565 (Android) the icon to expand the view to full-screen is missing. I cleared cache and even un-installed/reinstalled the app with no success.
Please help. The live feed is way to small without being able to go to full-screen.
Forgetting and re-adding the cameras seems to have done the trick.
If you mean live view, I see a double-headed arrow in the top right of the camera view. I'm using the new user interface (UI) that uses Feed to view recordings. If you're using the same UI, go to Devices for live viewing on the camera to see this or, in Dashboard, be sure to use the large widget so you get the arrows.
Thanks for the suggestions jguerdat, unfortunately I don't see the double-headed arrow under Devices when viewing a live camera feed. The only icons that appear are the microphone, record, and camera icons.
As mentioned, I'm using the latest Android version of the app. In this version, the primary app buttons are Devices, Library, and Mode.
The doubleheaded arrow icon used to appear in this live view at the top right like you're seeing. For me, it is now missing.
I was not able to replicate this issue, does this occur on any other Android devices by chance?
Not sure. I don't have another Android device to test. This repros on a Samsung Galaxy Note 20 Ultra, even on a fresh install.
Which version of Android are you using? I couldn't replicate on an android device when testing.
Android 13. OneUI 5.1
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
