No feeds downloading
  • 2 Replies
  • 1766 Views
tbhholland
Hi, My continuing problems.  I changed batteries this morning .  Pre battery change, I had plenty of feeds downloaded for the day.  After the battery change, none at all have downloaded.  The last feeds listed are from the pre-change.  Live view is unaffected.  The image is there and the live view works.  Any suggestions?  Is this a case where in 2 hours, I'll have a backlog of feeds downloaded?  Thanks
I had a delayed video yesterday but only one. You could try rebooting the camera or reinserting the battery to see if that helps but if it's a server-side issue, all you can do is wait.
tbhholland
Thanks,  I restarted the camera and re-inserted the battery.  I guess it's a waiting game now.
