My VMB4000r3 will not live stream
Recently all 5 cameras will no longer 'live stream'.
I have done EVERYTHING, reset modem / router / base / cameras / tried different browsers / cleared data / hopped on one foot while whistling dixie.
It was all working a few days ago.
I'm running the latest firmware: 1.21.1.0_4300_898b168
The App on my Android works fine.
Also, I can use the positioning in the settings and get a live feed.
But when I click the play button on the web app, I get the 3 dots... and then 'The request timed out'
It does detect and record clips - just the live view is failing.
Update!
I restarted the base station a couple more times - and I noticed a message about the Firmware updating....
So now I am at: 1.21.1.0_4302_9611cf3
But, still no live stream.
Here is a link providing some troubleshooting steps. If going through these steps does not work, please provide your internet speed. Also, make sure all the cameras are on the updated firmware as well.
I have Cox Gigabit - about 950 mbit down / 115 mbit up
So, plenty of speed.
Also everything is showing latest firmware, with no updates available.
Please reach out to the Support Team to further investigate this issue you are experiencing. You can find several options for contacting support though the Arlo Mobile App by navigating to Settings/System/Support.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
