  • 5 Replies
  • 2636 Views
885ojm
Can I just mute a couple of my cameras instead of all of them? I have 6 cameras and only want two of them to show notifications
5 REPLIES 5
Do you see "Library" in your app interface?  Or do you see "Feed" and "Dashboard" instead?
Do you just want to mute the notifications, or do you also want to disable recordings?
Do you want to mute the notifications all the time?  Or just sometimes?
885ojm
I see Library, and I would like to mute notifications forever on 4 cameras, while allowing notification of two cameras
Thanks!
Thanks!
You didn't say whether you wanted to continue recording motion events for those 4 cameras or not.
You can edit the armed mode and turn off the notifications for any camera there.
885ojm
I want to continue recording on all devices, but I don't need notifications on 4 of the cameras.
Then use the guide I linked in above, and modify the armed mode to remove the notifications for those cameras.
