HP ENVY *360 Convertible
@Evan_Roland wrote:
Is Arlo Secure compatible with my windows 11 HP Envy 360
It should work fine. If you have an older Envy (HP launched the Envvy 360 back in 2014), you should double-check that the PC has HEVC hardware acceleration. HEVC is used by Arlo for 2K and 4K camera recordings.
You can check that by looking at the video here:
Use Chrome or Edge (not FireFox), and don't changed the settings on the right side of the screen. Just click on the play option. If it plays, then your Envy can play HEVC recordings.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
