Instantaneous Siren activation in Home and Away modes
How do I enable instantaneous siren activation in Home and Away modes and not have to wait 60 seconds when either access or motion is detected?
There is no such setting since the siren should immediately sound. I tested my sirens recently and detection caused the siren to sound essentially when the recording started.
It clearly states in the iPhone iOS app "Panic will activate in 60 seconds" and the counter keeps decrementing when motion is detected in Away mode or Access is detected in Home mode. The Siren does not sound immediately.
I guess that's a difference I can't help with since I use Android.
Are you talking about the home security system "Panic Alarm"???
Is "Activate Siren" enabled in the camera rules in Armed Home and Armed Away? If it is, then the siren should engage immediately whenever the camera detects motion.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
