Help with new App
OMG, I am LITERALLY a rocket scientist, have designed spacecraft that have gone to other planets, and this is the worst, most confusing app I have ever seen.
Can someone tell me how to do this?
- I have outdoor cameras that I want enabled from 12am-5am when Home, and sunset to sunrise when I'm Away. I have the camera to only alert when detecting people.
- I have indoor cameras that I want enabled from 12am-5am with alerts when Home, and always with alerts when I'm Away.
- I have a video doorbell that I want enabled from 12am-5am with alerts when Home, enabled with alerts sunset to sunrise when Away.
I can setup Home/Standby:
Home: Indoor cameras, outdoor cameras, doorbell enabled
Standby: All disabled
Home automation schedule:
- switch to disabled at 12am
Since I'll now be in Standby at 12 do I need to add an automation schedule in Standby to switch to Home at 5am?
I assume when I'm away I manually enter Away mode. I can define Away as everything enabled. I can add a schedule to Away but the only option is to change to another mode Home or Standby or to change a device setting like motion sensitivity. While in Away how do i set up schedules for my devices?
You could create "routines" & "automations" for your cameras to be armed and disarmed during the times you mentioned.
How to setup Schedules for my Arlo security devices - YouTube
Well, duh. The problem is, with Schedules, you can only switch between Away, Home and Standby, or change a setting on your camera.
I've set up:
Away: Outdoor Disarmed, Indoor Armed, Doorbell armed
Home: Everything armed
Standby: Everything off
Scheduling:
12 am Standby-> Home, (Home and Standby Enabled)
5 am Home-> Standby (Home and Standby Enabled)
Sunset: Away->Home (Home and Away Enabled)
Sunrise: Home-> Away (Home and Away Enabled)
I'm guessing under the "Enabled" setting in the Home<->Standby Schedules if I only "always enable" Home and Standby, the system knows to not do the Standby->Away. Likewise when in Away<-> Home schedules, if I only "always enable" Home and Away, it will know not to do the Home->Standby. We'll see if that's how it works.
If this is how it works, some additional wording under the Enable option such as: "after this Schedule has executed, other Schedules that switch to modes that have not been set to Active here will not be executed." Right now it says: "By default Automations will be Always be enabled when you any Mode. All other automations will be disabled when entering this mode." ??
As others have said, a few examples would be beneficial.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
