Hi all. Is it possible for someone else to be paired to my cameras without my knowledge?
No. Why do you ask?
My cameras keep clicking all night even though I’ve fully charged them and turned them off via my Arlo app and the red lights are clicking on and off like someone’s trying to turn them on
The cameras may be detecting motion. You may want to check the camera positioning to eliminate unwanted parts of the camera view to minimize what could be causing this as well as reducing the motion detection setting in your modes and rules (or the Default Mode Settings if using the new user interface that uses Feed to view videos). An additional step may be to disable/remove activity zones and Smart notifications so you can see if recordings are actually being made and shown in the Library or Feed.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
