  • 8 Replies
  • 3908 Views
  • 2 Likes
Lauravet
Last week we were forced to update to the App 4 version. Since then geofencing has not worked on any phones. We have uninstalled/reinstalled apps on phones. We have deleted and reinstalled automations for geofencing. We have scanned the wifi for disruptions. We have checked location services on all the phones and they are all set up as they should be. Some phones are iphones and some are android. None of them are working. There was no issue with geofencing before the app upgrade. Is there a fix for this? Arlo support just keep giving me bull**bleep** stuff to try and none of it is working.
8 REPLIES 8
BrookeN
I am assuming these are shared devices on the account correct? Are all the phones showing feed or library?
Lauravet
They are all shared devices with location services set to ALWAYS and PRECISE LOCATION. All phones can see the feed and devices when they log on. When I look at available Geofenced devices they all appear on the list.
BrookeN
Here is some steps to set up the Geofencing. It is a tad different in the new user interface.
https://kb.arlo.com/000062942/How-do-I-add-a-Schedule-Automation-to-my-Arlo-system
Lauravet
I have done all this. Arlo are saying it is set up correctly but apparently it is still not working. Either the homebases are recognising the phones or the automation is not working.
BrookeN
Please contact support. Within the app on your mobile device click on the silhouette on the top left ~ support center ~ the device that you are needing assistance with then choose the issue. Support is open 7 days a week from 6 am ~ 6pm PT.
JeffHH
I am having the exact same issue
BrookeN
On the shared account is it showing library or feed?
MichaelT90
I've just had confirmation from support that if you use schedules and geofencing on the same account they conflict and don't work as they try to cancel eachother out.
Used to work in the old app, but not the new one.
They've also half said that geofencing isn't the most reliable.... So perhaps we all just have to stick with schedules only?
Btw, it's taken about 2 months to get that answer 😞
