If you’re using Apple device to access the subscription then try using a pc browser to my.arlo.com to update subscription.
jameshs888,
What are you experiencing when you try to purchase a subscription? Are you getting an error message during checkout?
Another day, another endless roundabout of re-booting garbage just to get it to stay on, never mind actually do anything.
Every single camera I own is within 25 feet of the base station, and my internet is 300mb fibre optic right into my house.
I can download a 2gb movie in less than 5 minutes but Arlo cameras can't even stream un-interupted that long.
What's the answer James?
Re-boot the base station?
So choosing the CVR option allows you to obtain the arlo secure subscription, or was this a typo?
I previously read arlo articles that state that the CVR plan is a separate plan to the secure plan and you can’t have both, either one or the other but your saying you have to select the secure option to access the CVR plan.
Was the CVR plan what you were after since you would be unable to download recordings, only view them.
You can have both, I have a subscription plan for smart detections, activity zones and cloud storage, and I frequently get offered a 24/7 recording cvr plan, so if I can't have it why does Arlo offer it to me then?
Arlo can't even get their own useless articles right clearly.
@jameshs888 wrote:
Ok. what I had to do was open the app, settings, subscriptions, the choose the arlo secure not the CVR option. when the next page opens THEN choose the CVR for $9.99. Put in payment info. Place for city and state doesn't show up right away. Had to fill that in after zip code. THEN you can agree and continue and what not. Everything and all came working as they should so far. Had to figure this out on my own. Arlo needs to remove the dead end option.
Something definitely not right here, since the Essential and Essential Spotlight cameras don't support CVR (but do support Arlo Secure).
If you go into your subscription settings, are you seeing any cameras listed under Arlo Secure? Or is there a "subscribe now" control next to it?
Is CVR subscribed, or does it say "subscribe now"?
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
