So what happened ?
Why am I not suprised .....its the one thing their good at , how long since you spoke to them about ? This new bad atitude is ruining what was a really good product but they really dont seem to care .
@Tp2 It has always been like that with a subscription overriding the trial. That is why I waited until a few days before it expired to sign up. Mabey support will help but the way it is now I wouldn't hold my breath.
Did you actually cancel the trial subscription? OR is it still in effect?
If the trial is still active, then cancel the paid subscription ASAP. They will at least give you a pro-rated refund.
But if you actually chose to cancel the trial, then I think you are out of luck.
@StephenB wrote:Did you actually cancel the trial subscription? OR is it still in effect?
Even the mods confirmed the sub overrode that way unless something changed. but it is a good idea
The current behavior makes sense if you already have a subscription, and are just adding more cameras to it. Obviously not so much if you are expecting the system to convert the trial to paid.
While we are talking about this would adding another smart hub while on a trial change anything cost wise ?
It shouldn't.
Shouldnt or wont ......I feel a little uneasy Steve .....just to clarify further I have a 5000 but because of range have got hold of a 4500 . I dont want mess up the trial as it has 9 months to go but I am struggling with one hub .
Sorry meant to put I have a 5000 and now a 4540
Heads up to anyone wanting to run local storage.... it only allows the primary to view local storage (recorded videos). They want folks to subscribe to their cloud services. Arlo support said they would look into expanding any secondary user access to local recordings... This is the worst... As a result I would discourage anyone from getting any of these products. Their Customer Service is really bad... you can see it throughout the community forum... do not deal with Arlo or any of their products..
@Chuck968 I agree it would be useful feature to add but it is not a hidden secret.
What is Direct Storage Access and how do I use it? (arlo.com)
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
