Arlo secure automation question
  • 1 Reply
  • 2145 Views
  • 4 Likes
Eyball
Is there anyway to configure automations so Geofence return goes back to previous active mode?   For instance, I use an arm at home mode during part of the day and arm away at night.  If I am in one of these modes when I leave it will arm away which is fine but when I return my settings go to standby.  It would be nice if arriving could could use the correct mode but I still don’t think this is an option in the new app.  I noticed you can disable certain automations when in a certain mode but it looks like geofencing is either off or on.  That might work for my nightly arm away unless I left and came back after my mode changes in the morning.  But what about when I leave during the day?  I want it to arm but depending on when I come back I might want it to arm at home rather than standby.  Hope this makes some sense.  😂🤔
@JamesC , @ShayneS  - same here. If you're not aware of this, you can end up in the wrong mode.
